I've got an Intex 14' pool (details below) and the sand filter pump - so it should have sufficient suction to support this.
I bought this skimmer which was promising. However the dual filter outlets seem to be confusing me.
https://www.amazon.com/gp/aw/d/B00178IMPO/ref=ya_aw_od_pi?ie=UTF8&psc=1
I would assume that 2 outlets into one hose means that if one outlet is closed off/blocked that 100% of the suction would be through one of the outlets. However I can't seem to validate this concept as any time I try to hook it up, the skimmer gets zero suction (with both outlets enabled or one blocked to try to give it 100% of the suction)
I have triple checked the manuals. I don't see anything that helps. Anyone else have a dual outlet (state of Virginia requirement or something?) and a skimmer that works?
Pool details:
* Intex Ultra Frame 14 ft x 42 in Round Pool 28309EH [new]
* Intex Krystal Clear Saltwater Chlorine Generator CS8110 [
* Intex Krystal Clear Sand Filter Pump SF10110 [used]
* 2x Intex 1.25" to 1.5" Type B Hose Adapters for Pumps & Saltwater System 10722/25009 [new]
* Intex Deluxe Wall Mount Surface Skimmer 28000E [new]
* Water capacity: 3,357 gallons (90%)
Pool details:
