do you have any pics of the pool so we can watch your progress? i love pics, also how about a full set of test results so all the brainiacs on this site can assist you better......lol @ brainiacs...keep up the good work.......Mike
fast1971chevelle said:do you have any pics of the pool so we can watch your progress? i love pics, also how about a full set of test results so all the brainiacs on this site can assist you better......lol @ brainiacs...keep up the good work.......Mike
fast1971chevelle said:in your second pic your water looks a little low it should be just above the return jet also if that is stabilizer in that panty hose you dont want to let that lay against the side of the pool as it tends to discolor the liner, if it was me i would have the pump running 24/7 to thouroughly mix the chemicles....but jmo
techguy said:Based on the photos of before and now, it looks like you have made some progress. Keep your FC (bleach) levels up and it will loose the green and turn more a more milky grey-blue/white. Once all the algae is dead (white stuff in water) you will need to focus on filtering your water. Do not expect the stuff to go away soon with your small Intex cartridge filter. You will need to keep an eye on your flow through the filter and change (swap with a cleaned one) when the flow slows down. I assumed you do not have a pressure gauge. When I am filtering for algae, I like to change the return water's flow up to the surface so it makes noise (gurgling or splashing), when the pool makes less noise (or none) you know you need to swap filters and clean the one you removed. You could even zip tie the return hose to frame top rail so it makes more noise, use the winter plug in the return fitting to keep the water in the pool.
Have patience and keep your bleach levels up until your water is clear. You might consider upgrading your filter when you can.
techguy said:You could even zip tie the return hose to frame top rail so it makes more noise, use the winter plug in the return fitting to keep the water in the pool.
