- Sep 15, 2020
- 29
- Vinyl
- Intex Krystal Clear
I don't recall, but does that o-ring need a little pool silicone? Might that help?Oring looks perfect (new thIs spring). Any suggestions on how to fix?
I did put some Vaseline on it just in case- no change...I don't recall, but does that o-ring need a little pool silicone? Might that help?
Then I'd go with what Msch99 recommended. Probably much better without the aeration. FYI - Future reference, never use petroleum jelly products on pool seals or o-rings. It will tear them up. Always use pool silicone. Have a nice weekend.I did put some Vaseline on it just in case- no change...
New out of the blue leak - but only when the pump is NOT running. I plugged the inside of the pool, removed, cleaned and put back in place. Still leaking. Oring looks perfect (new thIs spring). Any suggestions on how to fix?View attachment 163732
