Hi all. Brand new user here so please bear with me.
We have just set up a 16x32 foot intex above ground with an Swg. I’m currently in the process of finishing up the water setup.
I added salt yesterday afternoon about this time. Walked around the pool brushing the salt around until it dissolved. I’ve run the filter (not the chlorinator) for the last 24 hrs as recommended in my instructions.
According to the manual it’s now time to start the chlorinator but it’s pretty vague on how long to run the chlorinator.
It’s taken about 4 days to get the pool filled, the filter running (I added a Hayward skimmer and had plumbing issues that took a day or so to work out), and the salt added.
Now I’ve noticed that the inside and bottom of the pool is slimy which I assume is algae buildup.
So for my questions,
1. should I add chlorine to the pool initially? Is there a calculator for how much based on my pool size?
2. do I run the chlorinator instead of adding chlorine? Or do I run the chlorinator in addition to adding chlorine?
3. my filter has a chlorinator boost function also. Do I go ahead and run the boost? If so, how long? With or without adding chlorine?
Thanks in advance for your help and patience!!
Marc
Katy, Tx
Marc
Katy, Tx
