Finally installed EVC225. Installation wasn't as straightforward as expected because of differences in online videos vs the actual motor/pump I had. The pump seal plate bolts wouldn't budge. Took lots of WD40 and elbow grease but got them out without breaking anything. Then, cleaning the threads so they'll go into the new pump also took some time. Could've just bought new ones but an online check at both HD and Lowes didn't show them in stock. Another issue was the shaft seal, how to remove it, etc. It'd have gone a lot quicker knowing what I know now. In any case, all done.
Now, I have it set to operate at 1100 RPM (vs 3450 at full power). SWG is not complaining about inadequate flow and my skimmers are collecting the surface debris, so all looks good.
One item I'm noticing at the lower speed is the amount of small bubbles the SWG actually produces. I can see these through the SWG clear housing as well as small bubbles constantly coming out of one of the pool jets. Weird that only one jet has the bubbles. It's not air because I ran the pump at full power to pull all the air in the lines out. Is this normal?
BTW, old motor was actually running fine at night. I was especially diligent to keep the skimmer and pump baskets clean of debris.
