Hi, welcome to TFP! If you are seeing fine air bubbles coming from the returns from time to time it is probably coming from the saltwater chlorine generator. Is the pump strainer pot always full of water with no air bubble in the lid?
Man you were right, went over turned off the swg they stopped immediately. Came back one I turned it on. Any advice on getting the last bit of air out the pump?
You may have an air leak somewhere on the suction side. Here are some things to check. Make sure the o-ring on the pump pot lid is well lubricated with silicone pool lube. Check that the plug on the pump pot is finger tight. Check any pipe joints above ground between the pool and the pump intake with soapy water while the pump is running. If the bubbles get pulled into the pipe that is the leak location.
So the problem was with the crappy sand filter I had. I bought a nanny installed it and once the vs pump started to prime the air was completely gone in like 10 secs
