- Dec 14, 2021
- 288
- Plaster
- Pentair Intellichlor IC-60
Any advice with regards to finding a vendor that has a 3HP IntelliFloXF 022056 in stock? I actually need 3. TIA
Thanks Jim. My PB has been waiting on them since 6/6 from their distributor. I thought I'd ask the forum to see if I got lucky.Duff,
I talked to these guys about Pentair equipment always being out of stock. They said they are always getting new equipment in, but it goes right back out the doors to those on their waiting list.
I have no clue what their wait time is, but it can't hurt to get on their list.
Connecting to an Automation System
All IntelliFlo3 VSF and IntelliPro3 VSF pumps are compatible with Pentair automation systems.
Refer to the automation system manual for further details on connecting your pump to a specific automation system.
Note that that the above part number is discontinued and the new part number is below.Duff,
https://www.polytecpools.com/Pentair-IntelliFloXF-VS-Variable-Speed-Pump_p_8843.html
Yes, I reference 022056 when I inquire. Awaiting response from the PB regarding Pool 360. Regarding a substitute pump if the XF is not available, the PB has asked whether I'd be interested in an IntelliFlo3 but I also see there's an IntelliPro 3 which is a 4HP. Could I perhaps mix and match based on system requirements(filter/Infinity edge/water features)?Note that that the above part number is discontinued and the new part number is below.
https://www.polytecpools.com/Pentair-IntelliFloXF-VSF-Variable-Speed-Pump-_p_9514.html
Using the old part number might cause a bad "Out of Stock" notice.
The IntelliPro3 is the same as the IntelliFlo3.the PB has asked whether I'd be interested in an IntelliFlo3 but I also see there's an IntelliPro 3 which is a 4HP.
IntelliPro3® VSF Pool Pump
The IntelliPro3 VSF pool pump auto-regulating flow technology increases efficiency and energy savings. All for an effortless pool experience.www.pentair.com
I think that the only difference is the color.What is the difference between the IntelliPro3 is the same as the IntelliFlo3? Is the Pro Trade Grade?
That should work.@JamesW
Based on the flow calcs you preformed, could I can use different pumps on different systems and not jeopardize performance? For example the IntelliPro XF for the water features and/or infinity edge and an IntelliFlo3 or IntelliFlo VSF as the filter pump?
Therefore:For the filter, I think that during spa jet operation will be the highest flow with 6 jets at 20 gpm per jet, which is 120 gpm total.
The IntelliFlo VSF or IntelliFlo3 should be able to do that.
