Intelliflow VS - impeller issue or air leak
Pull it apart. See what the issue is.
As I was looking to undo the screws saw some gaps on the wet side and also corrosion.
Attached are the results.
Final result - shaft is broken
Seems water leaked over the season and ultimately froze in winters.
I would never recommend the de-rated VS pump. You would have to run it at a higher rpm and thus more electrical expense.
