I currently have a wfds-8 whisperflo 2 hp 2 speed pump, which has died. I wanted to replace it with the same but Amazon and my local stores don't have it in stock.
I started reading about Pentair intelliflo VS 11018 and it looks like a good prospect.
I have several considerations though:
1) Whoever set up the pump (for the previous home owner), left no room for cutting and joining pipes. The plumbing is essentially a bunch of couplings connecting the pump to the filter. Is the intelliflo body same as whisperflo (my idea is to keep the same plumbing and volute, only replace the back end).
2) I currently have a Polaris 380 with a screeching booster pump, which I would like to replace. Will the polaris 380 run on the intelliflo. I don't mind buying a new cleaner (like Pentair LX5005 Kreepy Krauly Legend II, which doesn't need a booster. Is this a good cleaner like Polaris 380.
3) My wiring currently includes a T104 timer with a relay switch to toggle from high to low speed. There is a toggle switch that brings the pump on at low speed, the T104 timer with the relay then switches the high on/off, and also turns the polaris booster off when it goes to low again (Polaris booster has to be turn on manually with a toggle switch). What would be the best way to rewire this or reset this arrangement.
I am sorry for the long post, but thanks for reading. If you have any time for adding an input, I will be delighted and highly appreciate your help.
Best
Best
