All the sudden 5 days ago I got this message on my Pentair-Home app, "communication error has been detected between your IntelliConnect and your intelliFlo. This may be because:
1) The communication cable is not installed properly per instruction manual. Ensure that the green and yellow communication wires in the low voltage side of the IntelliConnect control panel are not damaged and are properly connected.
2)The IntelliFlo does not have power
I checked all cables, and everything seems to be good (no changes from a few days ago). I am not sure why all the sudden this happened. My chlorine output is at "0" and cannot change it from the app or the equipment. when i try to increase from the ichlor-30 system manually, nothing happens when I press the "more" button.
I have been adding liquid chlorine so far and I scheduled a service person to come look at this, but any insight? has anyone have this happened?
UPDATE: I got it to work in the app!! apparently, it was disconnected... I feel so happy that it was that but at the same time so silly to not realized it for so long! now the only issue is that can only change the chlorine output from the app and not from the system itself. is this normal?
Thanks in advance.
Thanks in advance.
