I have an IC20 pentair Intellichlor. And I noticed one day that there were no lights on the cell at all. After troubleshooting, I found that the fuse in the power center had blown. I replaced the fuse and turned the system on and the fuse immediately blew again.
I'm wondering if the cell is likely dead? I disconnected the cell's power cord and ran the pump again for a few minutes. In that case the fuse did not blow. It will only blows if I connect it to the cell. The cell is older...probably 4 years or so. I just don't want to buy a new cell if the power center is the problem.
Also, would I be able to use this chance to upgrade to the IC40 with the same power center?
Thanks for any advice!
