Build a shade structure, drill a hole, filter cleaning....did everyone but me miss this part?
laziness is the ultimate factor in deciding what to do
I just got all my parts on Amazon but did not have time yet to do the thermistor hack. Planning on Saturday. I did get my SWG running again though by adding 40lbs of softener salt. My salinity was at 2700ppm (K-1766) and so it was definitely low to begin with so the dead thermistor only exacerbated the false low. After bumping it up to 3000ppm, my IntelliChlor started generating again even though the diagnostic check still shows a dead thermistor (all flashing LEDs). But, because the water temp is 76F the salinity readout from the IC was 2950ppm since the system defaults to a temperature of 76F when the thermistor is dead. So the IC is totally fine, it’s simply the dead thermistor causing bogus readings (except when the water temp is 75F).
Like I said, I have all the parts to do the hack and bypass the flow switch thermistor. Just working up the energy to get off the couch and do it ....![]()
