Hi everyone,
Hoping the community can help me out as I’ve had no luck with Pentair nor the installer that completed the work. When my IntelliCenter is in pool mode, the intake valve is powered off and the return valve is powered on. All is good until I put it in spa mode.
When I enable Spa mode, the return valve rotates to the pool side (pool closed) and the intake valve powers on, flashes blue and then stays on the spa side (spa closed). I have to manually switch it to pool side (pool closed). Then before turning the spa off, I have to manually switch it back to the spa side (spa closed) otherwise I wake up to an empty spa in the morning when the filter kicks on.
I’ve tried switch the valves in the circuit board with the same results. I’ve reconfigured the system fully and it performs the same way.
Any thoughts would be super appreciated!
