I am a bit confused on initial setup of my i8ps intellicenter and intellivalves for the following configuration:
Elevated spa spilling into pool
Single VSF pump and filter used for both pool and spa
Shared Equipment configuration - per the manual (but not mentioned anywhere in configuring that I can find)
Intake and return intellivalves with each one plumbed to pool or spa
We always have the spa spilling into pool in pool mode - intake valve set to pool and return valve set to spa
In spa mode the intake valve is set to spa and the return valve is set to spa
The valves are connected to intake and return valves connections on the intellicenter
Currently it was configured by the pool guy as two bodies labeled pool and spa
He has Valve A to pool (but nothing is connected to Valve A on the circuit board)
He has Valve B to spa (but nothing is connected to Valve B on the circuit board)
The intake and returns valve settings are greyed out set to pool/spa in the configuration
In pool mode, no valves move.
In spa mode, both valves move to the opposite.
I understand how to change the Home location of the valves. The home position of both valves is in the pool position.
I want both the intake and return valves to return to the pool location when the system is off. When turned on in the pool mode, I want the intake valve to remain at the pool location and the return valve to switch to spa location. When turned on in spa mode, I want the intake and return valves to switch to the spa locations.
The pool guy doesn't seem to understand this system, and I find the manuals a bit, well, underwhelming in terms of explaining the interfunctionality of these bits.
Can you please help me?
Mike
Mike
