I’ll soon be installing a fiberglass pool with Pentair LED Lights, colorvision bubblers, and Magicstream laminars. Will I need a separate low voltage transformer to wire the LED lights or does the Intellicenter not need a separate transformer?
You will need a transformer for each set of lights you want to control independently. If all the lights will operate at the same time with the same color scheme, I believe one transformer will work. You state a number of lights so check that.
