- Jul 1, 2020
- 1,442
- Vinyl
- Hayward Aqua Rite (T-15)
If they are loud they are about to go.I have one LED out also. Motors are super loud right now. But both are still working.
Is the paddle turning? If not check if there is debris wrapped around the sides where it connects to the body. fine threadlike stuff gets wrapped around sometimes making it difficult for paddle to paddle.My v1 Betta is moving about the pool, but the surface debris isn't entering the basket! The debris just gets pushed forward by the Betta, and ive never observed this behavior before. Anyone ever see this?
Sounds like you need to send it back if it’s under warranty. I think that’s the first time we have heard of that part failing.Thanks @Bam Bam . The paddle wheel is not turning, nor is the small red wheel inside the Betta (the one that turns the gear on the debris basket which moves the paddle). This wheel can be turned by hand fairly easily, but it's not turning when the Betta is in the water. I put a little WD-40 on its shaft but that didn't help.
Thanks - I contacted them, filled out a warranty claim form, and just awaiting the return label. They offered to send me the gear but I don't think it's just the gear, so I opted for the return.Sounds like you need to send it back if it’s under warranty. I think that’s the first time we have heard of that part failing.
Good deal regardless of color. I like my white.Probably an irrelevant question but is there a longevity difference between the blue and white finish?
The se is on lighting deal for 399 so likely going to pull the trigger then register the warranty upon receipt and pay for the 3yr upgrade.
Where are you seeing it for $399? The website shows $439.90.The se is on lighting deal for 399
I got the email also but can't do it. My Betta's being repaired.I got the email as well, but have not done it yet.
I got it but wouldn't open, may try it again with ad blocker off. I emailed Betta, they said it was legit.Anyone else get an email from Betta about getting up to a 6 month warranty extension free by uploading a video? I stopped the process when they asked for personal info. Obviously it is needed but curious if anyone else went through to the end and what the reward was.
Betta
Solar Powered Smart Pool Skimmer
Share a video to get a 6-month warranty
extension on your Betta.
I think you should ask for an extension to submit!I got the email also but can't do it. My Betta's being repaired.![]()
Do they just want a video of Betta tootling around the pool?I got it but wouldn't open, may try it again with ad blocker off. I emailed Betta, they said it was legit.
I just did it, uploads your file to their Dropbox. Got no confirmation that my warranty was extended.
Yes, 30+ secondsDo they just want a video of Betta tootling around the pool?
My fear is that they will go out of business in order to get out from under the warranty claims.These repairs must be costing them a lot of shipping fees!
