- Jul 1, 2020
- 1,276
- Vinyl
- Hayward Aqua Rite (T-15)
I thought I would post my impressions of the Instapark betta and my experience with it. The beta does an excellent job cleaning the pool, it is the only skimmer I found on the market that has a very large container for collecting debris. I get a lot of pineneedles in my pool and this feature was the main selling point for me. The beta also comes with a remote control that you can drive the robot around manually with, and provides a convenient means to retrieve it from the pool, and to spot clean. It has a total of five different modes, which are indicated by the LEDs on the back of the unit. In it’s autonomous mode, the LEDs on the back blink blue. When the robot is being controlled with the remote control the LEDs are solid blue. When the robot is running low on power the LEDs will turn red. If robot experiences a fault or a jammed basket, the LEDs alternate between red and blue. When it is completely out of batteries it enters a sleep mode and no LED lights will display on the unit. The batteries seem to last a long time, as it can run all day and all night. However you cannot charge the unit with an outlet. It can only charge via the sun. What I have discovered is that if I run the robot a full day then let it run all night and if the next day is cloudy the robot will run out of power. This will require that the robot charges in the sun all day before it can run it again. Because of this, I choose not to run it at night, and it always seems to have enough power to run several overcast days in a row. This isn’t unique to the betta though as other solar skim bots are designed the same way. I wish that it had the option to charge it via an outlet.
I have had several issues with the product and I am on my third unit. The good news though is that the company is very responsive and when you have a problem they will ship you out a new one immediately. They also are constantly making updates to their robots and I am hopeful that they will eventually resolve the reliability issues myself and other owners have reported experiencing. There are at least three different versions of this robot that I am aware of at the time of this post. The first version of the robot apparently was having issues with their motors and they would not recommend the robots for use in salt water pools. The motors were rusting and seizing up apparently. The first one I received was the first version that was released for use for salt water pools and I have never experienced any issues with the motors on my previous two robots. The issue my first robot had was that it seemed to have gotten stuck in it’s error mode. When I would power on the robot all it would do is blink blue then red. Instapark sent me a new unit to replace it with. This robot seemed to do better and had its programming updated. The first robot seemed like it would just swim along in the pool full speed until it hit a wall. The new robot would slow down and turn before it would hit the wall. It also seems to do a better job avoiding objects in the pool. The issue that I eventually had with this robot was that it started swimming around in circles, which was a common problem on the first generation of robots due to the motors freezing up. That didn’t seem to be the case with this one though. I noticed that the robot would stop spinning in circles if it took up rather violent whack into the side of the pool. When it would start swimming in circles, I could give it a whack or two around it’s sensors and it would correct the issue for several days. The other issue it seemed to have, was it would go into its error mode when it would stubbornly try to fight the currents from the return jets. Instead of turning around to avoid going headlong into the current, it would eventually just give up and would enter into its error mode and start to flash blue and red. When this would happen I would have to turn it off and on again or just wait 20 minutes as the robot restarts itself 20 minutes after experiencing a fault. I have received my third robot last night, and I’ve yet to use it because it needs to charge. This new robot seems to be a different revision, because it has a much smaller power button then all of the previous ones. I’m not sure what the reasoning is for this but it does indicate to me that the company is making changes to the hardware of the robot on a fairly consistent basis. The newest revision as of the date of this post has a smaller button and red propellors. I will update this thread when I have more experience with this new robot. I am hopeful that this one doesn’t experience any issues, as when it’s working correctly it does a wonderful job and keeps my pool free of all the pine needles that I experience every time I have a massive storm. It does an excellent job keeping the pool clean. If it didn’t have the issues that I have experienced, I would be more than happy with it, and would highly recommend it to anyone.
