Installing replacement liner inside of Intex 18' metal frame
ilikesta
1
SALINA KS
This thread is awesome...i am getting ready to try this. I have a 16"x48" Intex ultra frame. I found a brand new 15x52 beaded replacement liner and am getting ready to give it a try. Anyone have an opinion on whether the 15" will fit inside the 16' frame. All my friends say it will stretch with the water weight. I think it will too.....Ill keep the forum inforumed
Coffeeguy
1
Liverpool/ ny
I have been reading through the threads here and made my decision to buy a new liner better. After 4 years of use my 16x48 has developed a number of pin hole leaks (too many to patch) so I am going to put the new overlap liner in.
One question I have seen a number of comments about not being able to line up the holes gin the next year. I do not have a choice up here in Upstate New York we get at least 142 Inches of snow and bitter cold temps so I have to drain and store. What I was wondering is after the water has pulled the liner down enough to stretch it before I cut the holes what about putting the vinyl adhesive on the wall to have it attach there? The other option would be to leave my suction and discharge units attached so the liner was secured to the old pool?
Momto3Redheads
2
Topeka, KS
I am so thankful for this forum! We have an intex ultra 20 ft x 54 in pool & it has developed a leak in the seam which patching, Flex Seal tape, flex seal spray...nothing works! So after reading this fabulous thread I ordered an overlap liner - I can’t wait for it to get here!!!
thanks so much for sharing your wisdom!
Shelby77
1
New castle pa
And I thank each and every one of you who contributed to this thread .I sat this morning wondering what to do about my pool and then I came upon this forum and thread and I'm fixin to order a liner!! Wish me luck.
dansmail26
1
lockport, ny
I live in upstate NY too but leave the pool up year round! It's been fine for 3 years, but a nephew through some bricks in it from around the filter and put a hole in it.
On ebay I found a liner that comes with round 'clamps' that hold the liner! check this out - https://www.ebay.com/itm/Tube-Frame...rentrq:300982fe1650ab68ebea31f0fffd5114|iid:1
Apolly
1
south Texas
Re: Installing replacement liner inside of Intex 18' metal f
I got the grommets from Harbor Freight. They are called "15 Piece Super Snap Grommet Value Pack". There are two pieces to each grommet that you don’t use any tools to install. You place the round piece behind the liner and then press the hollow piece in between the liner and round piece. It is kinda hard to get them to snap togethe with the 25ml liner but it does. My thumbs were sore after I was done. I placed one between each leg and ran a string from the grommet to the bottom to secure it. Hope this helps.
I am going to try this my question how or to what is the string attached to on the bottom the one in the image attached to the grommet what did you secure it too? I see it is all the way to bottom
tifanies
1
98607
I have an Intex 18'x48' pool that I just set up yesterday and unfortunately got a 5 inch tear near the bottom seam. I patched it with flex seal tape, a piece on the inside and one on the outside (this worked great last year for smaller holes closer to the top). So far it is holding, but am pretty worried that it will get more as the liner is on it's 5th year and I use saltwater.
After reading through these posts I have a couple questions. First is the expandable liner or the overlap liner preferable? Also as seen in the original post is it necessary to tape the frame at all the joints?
RonsPlc
898
Gaylesville, AL
I didn't tape mine, but I got the heaviest gauge overlap liner I could find, doubled it over on itself trapping a run of paracord for the tarp clamps to hold to in the fold.
You can see the results on page 10 of this thread.
I would be concerned with the length of the rip that you are expecting the flextape to hold together though, and would be seriously looking at a new pool, or liner.
Pv2
741
south east Arizona
that is the highest pressure, most stressful part of the pool. as impressed as I am with those flexseal products and as willing as I am to "ranch-rig" most things in my life, I don't think I would rely on it for a 5 inch tear near the bottom of a pool. maybe tons of it and with a liner too, but you are entering the realm of spending more to repair than replace.
Tharms
1
Louisville
I decided to be bold and take one for the better good of all other intex pool owners, I bought the 18'x52" liner to give it a try and hopefully prevail:) my hope is that I will have enough over hang to secure the tarp clips, I will try this later on today and report back to all!
Did the 18x52 overhang liner work?
cooljul
135
Fort Pierce, FL
I have less than a one inch tear but it’s just under the seam at the bottom of the pool. Just covered it on the outside and inside with flex seal tape. The pool had been drained while we re leveled and had about 2 inches of water in it when I noticed the leak. Let’s hope this holds, year 4 with the pool, and maybe replacement liners will be in stock later this year or just a whole new pool ?
HeyTherefromTX
1
San Marcos, tx
Hoping folks still monitor this thread. I have a Summerwaves 16x48 with a tear. Planned to follow this thread, and bought the tarp clips, paracord, and replacement liner. But.. the liner is 18x48 and my abg is 16x48. My bad for misreading. Should I try the larger liner, or send back and wait for the right size to be back in stock?
mavasmommy
1
Upper Midwest
Are you sure you can return it? I just bought mine and it said no returns. If you can't return, I would give it a shot. Keep posting and let us know how it goes. I will post mine as well. Excellent thread! THANK YOU to everyone that has contributed over the last few years!
mghjuno
7
Nashville, TN
Hi, I'm thinking of doing this mod unless I can find the leak(s) in my Summer Waves 15'x33" pool liner. I see some of you ran pipes for the pump outside the pool and have them hanging over into the water for the intake and return, and some of you cut holes in the liner to run the hoses where they went in the original liner. For those who made the cuts did you have any trouble doing this? How did you line it up do the cuts? My worry about making the cuts properly is the main thing preventing me from ordering a new overlap liner.
If I can't find the hole and don't do this mod I guess I'll live with the leak which isn't too bad yet, topping off the water every other day and hoping by next summer I can find an original replacement or entire new pool - I'm sure everyone has noticed that these Intex and Summer Waves type pools are nearly impossible to find this year!
RonsPlc
898
Gaylesville, AL
I filled with water to just below the holes, then cut them out using a scalpel blade.
I then attached my fittings, and prayed!
To my surprise, NO LEAKS!
Reactions: mghjuno
mghjuno
7
Nashville, TN
One more question for those who have done this mod. Did you order the same size as your pool (15' liner for a 15' pool)? I'm wondering if there will be enough stretch to go over the poles and overlap the sides, since I think these poles are thicker than the usual overlap on a permanent above ground. Or maybe they aren't thicker?
