I haven't swam in a Salt water pool yet ( water temp still around 62 ) but the water looks so soft. MY water fall usually splash's and makes sound but it's quiet. Not sue if that is the salt or my imagination.
That is a fantastic idea. I would worry about it sticking on, but with the flow switch as long as you checked on it periodically you should be adequately covered. I have a timer that is not hooked up to anything (no joke) but.. Hmm.. I do like that better... With the VS pump I bet you can even set the trip point when it's running on "high".... Cool... Clever...I use this current sensing device, (CR4395-EH-120-110-X-CD-ELR-I). It senses current on one of the pump's 220v lines and switches 120V to my SWCG. When the pump isn't turning there is no power to the SWCG. Current trip point is adjustable. If you don't have 120 available there is a version that can switch 220V (see the second page of the above link). Its a device used in industrial application for motor control and monitoring. Just need to mount it in a box (weatherproof if install is outdoors), make some twist nut connections along with crimping four disconnect terminals. In my opinion is is comparable in cost and installation ease to a timer
Their ‘tech support’ is reading from a computer prompt just like everybody else. ‘Ok now reset the unit and wait for it to reboot......’. You can’t deviate from the script and they can only advise you on the most common troubleshooting steps before deciding it needs to be shipped to an actual technician. Even THAT person probably only knows the flow chart of how to diagnose problems without ever caring to learn how any of it actually works.I asked and was pretty much told " don't worry about it, set and let it run" Guess they don't understand my brain
If/when I ever get one, I'll hook my scope up to the controller... I have read -- here--- there is so much information that it's sometimes hard to find some of it-- that the RJ and SJ series are on 100% for a certain amount of time (duty cycle) I could be wrong about this but it looks like the Edge might be different. Actually I would like to know because that would, IMHO, give the Edge an edge in my comparisons...
I am installing my RJ45+ today and also going to use a Smart wifi "outlet/plug" that measures energy consumption. I'll post back once I have some data on the RJ45+ series.....for us inquisitively challenged
I suppose that is what matters.My small smart plug doesn't give "daily" details but every time I check it's pulling 78 watts and never stops
Good news is it's on 3 of the 8 bars and my FC is 6 and holding![]()
Rattus, do yourself a favor and get it from tftkits.net. amazon has had old stock at some point. Get the freshest availableDo you know about how many tests you get out of a K-1766? And for the record, Amazon sucks in the Zombie Apocalypse...
I like the fact it's working all the time. Its pulling 11 watts now![]()
