Howdy all,
I test Chlorine, pH and TA at home but go to the pool store once a month to get other results such as CH and CYA. I then use this info, along with temp, in Pool Math to calculate CSI. I have a couple of questions about the numbers I'm inputting.
1. The TA number from the pool store "has been adjusted due to the effect of CyA on tested Total Alkalinity". Pool Math already asks about CYA. So I entered the adjusted TA or the unadjusted TA in Pool Math?
2. The water temp by the time I get to the pool store has changed. I'm not sure if this affects the test results. Do I enter the water temp actually in my pool? Or do I enter the water temp at the time it was tested at the store?
