I have an AG pool, approx 2900 gallons, that has 2 inlets and 1 outlet (hope this makes sense). I'm currently running 1.25" hoses buy have the fittings to go to 1.5" hoses. I got the dual valve that would connect the 2 inlet hoses to send to the pre-filter. My issue is I want to run 1.5" hoses from pool to the dual valve but - alas - the valve on the dual is 1.25" I would like to keep all the hoses on the system uniform size, 1.5" (I'm okay on sizing the outlet side - 1.5" plunger is installed). I've seen a few YT videos where bigger AG pools, than mine, have only 1 inlet and 1 outlet (once again apologize for the lack of using correct plumbing terms) and thus skipping the problem with sizing on the dual valve - they don't need it. My new sand pump came in and it is 2800gph .6 HP Intex.
My ideal setting was going to be use a skimmer and and extra water intake, but now if I want to stay 1.5" hose to pre-filter I will have to find something to do with the other inlet.
What are your suggestions?
