- Feb 17, 2022
- 386
- Plaster
- Pentair Intellichlor IC-40
My last two houses have rinnai tankless heaters. My biggest complaint is the amount of time it takes to get hot water to the location its needed. Tank water heaters are always hot and provide some heat into the lines always so the water at the tap increases in temp far quicker than the tankless. If you can install a recirc loop on the tankless, that should solve that problem. Something to think about, 1.5 GPM faucets, shower heads, etc... do not work well with tankless heaters (well mine at least) the flow out of them was too low to keep the heater running and would shut off mid shower which was not awesome. Scale build up is a thing here too. Some thought needs to be given to the hardness level of the water. A water softener may be required to keep the exchanger scale free and the other internal bits working well.
