In ground spa upgrade jets (6) - any suggestions would be appreciated
sgracian68
4
So Cal
Looking to change out simple eyeball jet to something else, Pool spa was re-plastered 10 years ago and in great condition, anyone done this before, apologies in advance Newbie..
Not sure what type of spa jets you have but some setups have the standard eyeball facing out on the spa wall but the actual jet is about 6 inches back in the pipe. It can be removed with a socket & wrench once you remove the standard eyeball.
Are you trying to improve the jet performance?
Your jets may be different setup. One way to check it, if you put in spa mode and your filter pressure gauge increases but you have standard eyeballs in the spa then there is a good chance your true jet is farther back in the pipe.
Not sure what you trying to achieve but hope this helps you think through options.
