I'm currently waiting for my TF-100 test kit. In the meantime, I am, of course, anxious to start fixing my pool. I found this site after some frustrations at my local pool store. I have only been a pool owner for 2 years and depended on them for answers. Starting last year, I was getting a very low reading for CYA and my chlorine levels would not hold. I dumped a lot of "powerful shock" into my pool. My pool store insisted that my CYA was "hiding". I still don't know what that is really all about. Finally, they recommended I treat for a chlorine mismatch ... I can't remember what they called it. I did their recommended addition and did start to get chlorine readings that lasted a bit longer, but my CYA was still low, so I started to secretly add stabilizer. I managed through the end of last season and closed the pool. This spring when I opened it, it was slightly green and cloudy. The pool store had me do an algae treatment. The water cleared up pretty fast, but my CYA was still low on my "AquaCheck" test strips that I was using, so I dumped some more stabilizer in along with 6 more pounds of Tidal Wave 73 shock before going back to the pool store to get my water tested. When they did my test they said my chlorine was at 0 and recommended I add a few bags. I asked about the CYA. They said it was on the low end, but I needed to add more shock. I told them I had added the 6 pounds of shock on top of the 6 pounds they initially had told me to use and that I had also added 5 pounds of stabilizer two days prior to bringing in my water for a sample. They almost bugged out and told me I shouldn't add stabilizer. I explained that I was tired of spending hundreds of dollars on shock and it just disappearing. Finally they said that I probably should treat for a chlorine demand if I had added that much shock and it was still reading 0. When they told me their cost to add the shock, I almost croaked. They then recommended an alternative of using Pristine Blue. As they explained it, it sounded like a good plan. Luckily I had plenty of the Caribbean Blue chemicals at home that I had just bought which they said they would exchange for the new system, so I left without committing to anything. When I got home I started reading about Pristine Blue and mostly found reviews saying - don't do it! Then I ended up on your website. I was at first confused, because most of the information I started finding talked about Slamming to cure a green or algae pool. My pool is clear. Finally I found some stuff about Ammonia. So, I bought an Ammonia test kit from my pet store. I know that was a lengthy start to my question, but I thought a bit of background might help.
My Ammonia kit said I had an ammonia level of 1.0.
My AquaChek strips (I'm still waiting for my test kit) still say 0 for both Total and Free Chlorine. PH looks okay. Alkalinity is a bit low. And CYA still appears to be 0.
Is there anything I can do to get started while I wait for my test kit or should I just try to find some patience?
Thank you for any help or suggestions!
