I think you are good, but just for kicks, do another OCLT tonight. Test FC when it’s dark, maybe around 9pm or so. Then test in morning before sun comes up. If you lose 1 FC or less, you pass OCLT.
Also test CC. If .5 or less, you pass that part.
And your water is clear. Those are the three criteria for calling your SLAM done!
The only other thing to do is get a handle on your CYA. Follow this method:
In sunlight, back to the sun, fill tube to first line. Quick glance, don’t stare! Still see dot?
Fill to next line, quick glance. Still see dot? Repeat.
The first line where you don’t see dot with a QUICK glance is your CYA. Maintain proper FC level accordingly.
