- Jul 21, 2013
- 65,340
- Plaster
- Pentair Intellichlor IC-60
I got my butt handed to me fixing that. And it's funny because a guy at work told me to hire a professional and I told him, I am the professional!Gotta give you props!!! You did some hard work especially with the heat. Great Job!!![]()
You can likely adjust your pump to go lower in the menu settings. The PB likely just picked a high and low threshold based on your SWG. Going with a lower RPM will free up the vacuum from sticking if the problem persists once this is done.
I'm thinking it was either a defective couple of feet of pipe and it collapsed, or they somehow crushed it and didn't realize it at the time. The PB will blame the soft toy (that can't make it through a straight pipe with no 90s), but this is his responsibility under warranty not yours.
I could only work with what I had and after throwing everything at it for 4 days and still not being able to get water through the pipe, I was done messing around with it. I was at my last resort n that was eliminating the line all together. It's done. I'm still tired over it. I have a lot of work to do to fix the landscaping now n most of all... I have water flow.Those were my thoughts as well.
The vacuum sucking to the pool bottom is not caused by a collapsing pipe, but it can help lead to a collapsing pipe. When the end of the vacuum sucks to the bottom the pump is going to build a negative pressure in the pipe, and if there is a weak section it can collapse it.
My ABG vacuum will suck to the bottom of my pool, especially after I bump my filter - and I only have 20' runs of hard pipe. It is just a matter of the RPMs being too high (or the brushed on your vacuum being worn)
Dragging a nut (or 3) through the pipe on a string is hardly a way to figure out what is going on in there. I have a bore scope and have scoped a number of my drain lines. It really is the only good way to figure out what is going on.
Any way, it is now a moot point, as the issue has been resolved. Happy to hear that.
And at that point, so what if it was aliens? It's not anymore.I have water flow.
Exactly. And I worked my behind off after being in a hot concrete jungle all day. 4 days was enough for me.And at that point, so what if it was aliens? It's not anymore.
I mean. We'll probably all debate it until the end of time, but the only meanful part is you have flow.
If u can get up early enough to beat the heat a little & get a 15-30 min soak in with a cup of coffeeI go to bed to early to actually enjoy it because it's so hot outside. I was in it with my granddaughter on Saturday night.
I get up at 0330. I can't get up any earlier. It hurts getting up that early! That's why I have a bed time of 2000.If u can get up early enough to beat the heat a little & get a 15-30 min soak in with a cup of coffee️ It will be
percent worth it! It’s the only time it’s cool enough here for the hot tub lately anyway - i have it turned down to 100. It’s been maintaining temp all by its little foam filled, roto molded self, I don’t think the heater has run in a month! I joke that I basically have a multiple human sized yeti cooler on my patio & that if it craps out we’ll fill it with ice & beer.
My kids are always like “Mom! we gotta go to school - get out of the hot tub already!!”![]()
Wowzers! Too early for me!!I get up at 0330. I can't get up any earlier. It hurts getting up that early! That's why I have a bed time of 2000.
