Is there a % of chlorine to be looking for? Scott is at Walmart but texted me to ask.Link-->SLAM Process
Thank you so much!! Hopefully he is still at Walmart!! Thanks so much everyone.Walmart usually has Pool Essentials 10% for under $6/gallon.
Be sure to check the date codes - the fresher the better. The code looks something like 23-125, where 23 is the year and 125 is the date of the year.
125 is the DAY # of the year. For example this would be in May.The code looks something like 23-125, where 23 is the year and 125 is the date of the year.
Good morning and Happy Father's Day to all that may apply to!! Yesterday was the day we had set aside to start the SLAM. Unfortunately our home air conditioner decided to fart twice and die so 90% of our day was spent trying to get comfortable in 90+ degree heat with humidity. So we are back. The ac is fixed ($$$) and now I can devote time to the SLAM. This link goes to the liquid chlorine we purchased at Lowe's. If anyone has experience with this brand and has any comments good or bad. Please let me know. We bought 4 bottles of it and can get more if needed.Home Depot, lowes, Menard, and the like. Pool stores in the worst case sells it at a premium. Make sure you change the strength in poolmath per the chlorine you're using as the liquid content will be more or less for the same outcome of FC gain. Keep the slam level up atleast every 2 hours for now so it can move along otherwise below slam level does nothing.
Are you signed into PoolMath with the same email/username and password you are using in the forum?The only option that comes close to sharing to the group is to share using a unique link. See screen shot below. View attachment 505166
SLAM level has nothing to do with your current FC level. It is entirely based on your current CYA level.Apparently bec my current FC level is 9, my SLAM target of 24 is "outside of recommended range". Should I ignore that warning?? Also, the last 36 hrs worth of results are below.
Home
Build Type: Vinyl
Volume: 8500 gallons
Latest Test Result Summary:
FC: 9.0 (55 minutes ago)
CC: 0.5 (55 minutes ago)
pH: 7.8 (55 minutes ago)
TA: 90 (55 minutes ago)
CH: 130 (55 minutes ago)
CYA: 60 (55 minutes ago)
Test Results 06-18-2023 @ 09:03 PM
Free Chlorine: 9.0
Combined Chlorine: 0.5
pH: 7.8
Total Alkalinity: 90
Calcium Hardness: 130
CYA: 60
Test Results 06-18-2023 @ 10:35 AM
Free Chlorine: 13.0
Combined Chlorine: 0.0
pH: 7.6
Total Alkalinity: 100
Calcium Hardness: 160
CYA: 76
Test Results 06-17-2023 @ 12:00 PM
Free Chlorine: 6.5
pH: 8.0
Calcium Hardness: 120
CYA: 60
Both use my emailAre you signed into PoolMath with the same email/username and password you are using in the forum?
I am confident. See attached screen shot.SLAM level has nothing to do with your current FC level. It is entirely based on your current CYA level.
When SLAMming, you can ignore the "outside of recommended range" messwge as long as you are confident of your CYA level and the SLAM level listed in the FC/CYA chart - FC/CYA Levels
Weird - on my iPhone and Android tablet, the app shows two options to share your PoolMath logs.Both use my email
Home
Build Type: Vinyl
Nothing added. I thought it was beyond weird.Odd you CYA went up - did you add anything?? That's going to make your SLAM target higher.
