I'm a failure for father's day
lowes stores it outside but not in the sun. I'm gonna try 1 case
Now it's testing at 15. I haven't put anything more in, all I did was brush the walls an hour ago. So the Lowe's is stronger then the labeled 10%? I'm so confused. I tested it twice two different kits.
Edit: Maybe its because I went back to 15k gallons pool in the math app? It was at 12k I changed it because we thought maybe that was messing with the numbers
Edit2: 12fc to 15fc seems like a lot for a 3k gallon difference though.
*Remember when testing drop size matters- hold the bottle straight up & down & let the drops fall naturally. It’s easy to overlook this when testing so frequently. Hopefully u got a potent batch of lc & you’re on your way 👍🏻Try to wait a little longer before testing so u know its good & mixed too.
Reactions: mguzzy and Bille
Wow, that's a lot of FC loss. It has to be hidden algae somewhere and/or the sun eating through a bunch, especially given your afternoon loss.
For the hidden algae, usually those are in lights (you said you have none), ladders (I cant remember if you have one and have removed/cleaned), water features, and skimmers. Double check and clean all that apply.
For your afternoon loss, have you checked your CYA recently? You want to keep it at around 30 so your FC doesnt get used up by the sun.
Reactions: Mdragger88
