G,
Pretty simple, just adjust the pump's speed until the flow light is off.. then slowly increase the speed a little at a time until until the flow light just comes on.. Add about 100 RPM and that is your best speed to run the SWCG.
I would not run less than 1,000 RPM just to keep the skimmers working..
I run at 1200 RPM but have a bigger pump and no heater. If you have a heater you will have to run at 1500 or so..
Each pool is different, so you just need to experiment to determine the speed that works best for you.
