Hello,
I've read through several related threads and attempted to troubleshoot my Pentair SWG on my own without any luck. Maybe someone can figure out what I missed! First a little overview and then I'll list the troubleshooting I've done:
IC40 purchased/installed last May (2021) worked fine all year
IC removed and dummy installed for winter (cell itself remained outside/connected to ET
IC only displays steady green flow light/salt indicator when pump is on; cell light/percentages are blank
ET diagnostic displays "communication lost" and salt level "0 ppm" This display remains anytime the pump is on (both on ET and SL app)
1. Had water tested at local shop; salt levels ~3300 ppm
2. Visual inspection of IC wiring checked out. Connection at ET look okay
3. During salt cell diagnostic mode I noticed the salt light displays red briefly but then returns to steady green
4. ET settings show IC enabled/100%
5. Did ET system reset with no change to IC
My next step is to reach out to Pentair, thought I'd post here first and see if anyone has suggestions.
Thanks in advance!
Thanks in advance!
