- Jul 21, 2013
- 65,175
- Plaster
- Pentair Intellichlor IC-60
Hello. The 3 jva run to “intake, cleaner and solar”
So now go to this page and assign the JVA to the AUX button you want.
Yep. I’m there. I got cleaner and solar working with 2 of my jva’s now. So those work well. . There’s one more for my water feature that’s not working. it’s plugged into “intake” on the app intake says “used”![]()
should I return this and get a pool only version?I suspect you had a pool only Aqualink board before and now got a Pool/Spa board.
With a Pool/Spa board the Intake and Return JVAs are assigned to be used for POLL mode and SPA mode. There is no way to change that.
Yes, you need the Pool only to get control of the third JVA you have.should I return this and get a pool only version?
