Seeing the green cloud with your own eyes so you know you have something in the water. Do a OCLT tonight to be sure what's going on.
Yes. Any added chlorine will give you a false pass.Do I turn off the inline chlorinator to do this test
You're better off. Some folks like to fail twice. If it helps them feel better about it, I'm OK with it. But visible algae is a instant fail.Well I slammed it tonight. I don’t need proof that something is wrong
No need until you have clear water. No alive algae, or the dead dusty stuff because you killed that stuff recently since your last vac.I’ll do the overnight chlorine test tomorrow after.
Bingo.I think my CYA is rising based on the chlorine pucks I'm using.
It works, but keep in mind that with each subsequent drain, you are also draining newer water, so each one gets less efficient.I plan on draining the pool a little each day to try to get my CYA back to 50
We redefine peoples definition of clear on the daily. Have you seen this thread : How Clear is TFP Clear?is the first time it has looked this nice!!!
