Sat morning update...
Everything going well - at least visually and with the filter.
Water looks WAY better! The green has lightened and I can see the entire bottom. Right now, since I don't have the FAS/DPD test I've been paying really close attention to the filter pressure. I got up throughout the night bumping and shocking. I also dropped the Dolphin in - which did a fantastic job getting the floor clean and must say is pretty freaking cool!
Here's the specifics - please stop me if you see something I should change! This may be a lot of detail, sorry if it's not that exciting
But, I like to post the info - it'll help me keep track. Thanks again all!
Fri/Sat (5pm to 7am): 4 cases of 10% shock total. Each time a "bump" is listed that means the pressure was up on the filter - which I equated to the filter working and eating up "dirt".
5:15pm: Shocked - First case of 10%
6pm: Dolphin dropped in (with bags)
7pm: Pressure up on filter. Successful bump. FC level: 7 or so. Shocked - 2nd case of 10%.
8pm: Pressure up, bumped again.
8:45pm: Dolphin cleaned and dropped back in.
9pm: FC test -
at this point realizing how pointless the test I have is for this - regardless, FC showed darker - guessing 10 or so?? Filter bumped again.
Scrubbed all sides VERY well. This really added a ton of crud to the water. I could see it all really well since it was dark and the pool light was on. At this point, I adjusted the jets to create a swirl back to the skimmer. I knew what I did helped when the chlorine tablet "floaty thing" started riding the wall towards the skimmer again and again. The flow towards the skimmer was MUCH BETTER and all of the crud was going directly towards it!
9:30pm: Shocked - 3rd case of 10%
10:15pm: Bumped. Pressure not all that high this time 26ish vs nearly 30. Hoping that meant less "dirt" was entering the system.
12:30am: Half asleep and too dark to see pressure, bumped anyway.
2am: Bumped.
3:30am: Bumped. Shocked - 4th case of 10%
7am: Not a good prime and pressure gauge "bouncy" at 24ish. Bump fixed prime and pressure no longer bouncy. FC level: Guessing 9 or so. Hard to tell.
The good thing, it was definitely darker, meaning the levels were at least getting higher. Dolphin dropped in for small stuff - with filters vs bags.
It's nearly 8am and I'm out of shock. Going to get more soon and will continue to shock based on filter pressure - that way I at least have some kind of "measure".
