Hi Experts!
I would like to purchase this robot but I have to upgrade my pump first and I have a ton of questions.
The current gear:
Intex Prism Frame 14'x42" Pool - has two outlets T-connected to pump (pool kit possibly only sold through Walmart Canada)
1000gph (standard kit) cartridge pump with 1 1/4" hoses
What I think I need:
[h=1]Intex 56633EG 2500gph or 56635EG 1500gph pump[/h]1 1/4" to 1 1/2" hose adaptors
1 1/2" hoses
Now... would I keep the current 2-outlet system or block one of them off?
If I have to block one, which one? The closer or the farther from the inlet?
Is there an advantage to the 2-outlet system? If so, and I keep it, I will also have to adapt the T connection to the larger hose diameter.
This would mean more points of failure (leakage), so I worry a bit.
Final question - I keep reading that you connect the robot cleaner to the INLET... how does this make any sense?
Thanks, guys!
