- Apr 22, 2019
- 422
- Vinyl
- CircuPool Core-55
I've had a problem with my pump since about the very end of the season last year and I have been trying to figure it out but I have no been successful. I am sure it is an air leak? But the symptoms have changed recently and I'm not sure anymore.
So, at first, the pump basket wasn't holding proper water level. After about an hour of being on, the water level in the pump would drop to about 1/2. In addition, I started noticing small bubbles in the return jets. This went on for a long time, but if I kicked the pump up to really high RPMs the basket would stay mostly full and it was functioning.
I tried several methods to find the air leak: shaving cream, incense smoke, looking for water or water spots around the piping. I changed the gasket in the lid of the pump basket, and lubed it up real well. Nothing helped.
This was a drastic difference from how my pump usually ran, which was that the basket always stayed full to the top.
Then about 3 weeks ago, we had a very very very heavy rainfall and... the pump basket was suddenly holding water, and the bubbles from the jets stopped. Now, the basket pretty much is staying full of water at all times, besides a small bubble, which looks normal.
HOWEVER. After the pump has been running for about an hour or 2, it seems to get very weak. The force out of the jets is low, and there is barely any turbulence on the water surface, and in the pump basket the bubble on the top hardly moves, and you can see a leaf or any debris gently flowing around in the bottom - not at all as turbulent as it should be. But the basket remains full of water. If I drop the RPMs really low (like 900), large bubbles will start coming out of the jets.
This is without changing the speed on the pump, it just slowly seems to lose the power to move water, over the course of an hour or 2. When I first restart it, it looks normal, after completing the prime phase (5 minutes).
I have had two professional installer/repair people come out and they don't seem to believe what I am describing is happening. The one today was essentially insulting my variable speed pump, saying that "people" buy them to save money but they just make you use more chemicals if you don't run your pump on 2800 at all times... even though I told him that the pool was a swamp last year, and even to clear that mess I never had to run it on 2800. I tried to tell him that last summer it was working fine, and that when I ran the pump on 1600 the water on the surface would be turbulent and the basket as well, but he just kept saying no. When he lowered the speed to 900 and bubbles started coming out, I thought he would listen then, but he just went back and set the speed to 2800, just kept going up and up until the bubbles went away and then said "see, no bubbles at 2800".
Last summer I set the pump on a schedule which was 1800 from 6am-noon to clean the surface, 1200 from noon-8pm, and then off from 8pm-6am. It worked great. The only time the pump ever was run as high as 2800 was when it was priming or backwashing.
I did discover today when I put the filter on recirculate, a steady fairly large stream of water comes out of the backwash pipe. I know that isn't good, but I also think that would be a separate issue. I also just replaced that entire filter head piece (you can't just buy the gasket for it anymore), so that was less than 5 months old and I can't believe it's failed already...
At this point I think I have to fix it myself and I could use some advice. Attached is a photo of the setup. The pump and filter are less than a year old.
