Hi there, I hope this is the right forum.
So Hurricane Helene flooded me with 3' of salt water (mixed in with sewer water, yuck). She did me the favor of a water change in my pool (34,000gal in ground, salt pool with cartridge filter, jandy pump, hayward chlorine).
I did a water replacement in place 3 days after the storm, I put a pump in the deep end (3/4 hp) and my garden hose in the shallow end, ran that for 3-4 days. I am guessing I got 60-75% of the water exchanged. this was about 5 weeks ago. in between I've been tossing in chlorine tabs, stabilizer, and a total of about 7 gallons of acid in the interim, and ran that same pump from the deep end to the shallow end to try to get some mixing. I also daily went out there with the rake and raked the bottom of the pool 6-7 times, even though I couldnt see what I was raking. by the end I was pulling up some leaves but not a lot.
Finally got my pump replaced today, and it is now running. current salt level is 1300 ppm. but I am still getting that nasty smell from the pool. I will be shocking it tomorrow.
Is there anything else I should be doing at this point to clean it up?
