- Jul 21, 2013
- 65,090
- Plaster
- Pentair Intellichlor IC-60
Thanks Dirk, do you have a link to those bundles that I can take a look?
what kind of digital input cable works with the Vgreen? I'm eyeing a $200 OBO used (4 years) waterway V165 pump but it doesn't come with any input cable.Dirk,
That's not quite correct. I used the digital inputs to accomplish these functions. For V-Green speeds are called Steps that are easily configurable. I configured mine as follows:
Step one is lowest speed and set with the internal timer to run 24 hrs per day. Digital inputs override the internal timer and when there's no digital input the motor reverts to the internal timer. All you have to do is run a signal wire to one of the 4 digital inputs that can be independently set to any speed. This triggers that speed as long as the signal exists. When solar valve is opened I use digital input powered from the solar 3-way valve signal to speed up to a higher speed. I do the same for the gas heater but take the signal from the gas valve solenoid to kick up to higher speed. There are a total of 4 digital inputs that can be configured this way. Digital input signals are very flexible, can be any signal from 9-30 volts AC or DC. You can do this with any automation system in place to control other components. For example I use the Intellicenter to control on-off of swg and make sure it can't run when the pump is off. So I can adjust run-time of swg to be less than pump run time if needed. Also use it for temp control of solar and gas heater which is all done using remote apps.
Chris
I am thinking it would be nice to use the digital input to ramp up the pump when solar valve is open so I can run the pump at low speed 24/7. Yes on the SWG, I already purchased a new blue works SWG BLH40 that came with 2 generic T-15 cells.If you're using digital inputs you don't need any special cable. I used multi-conductor cable you can buy at HD. 22 ga is fine. What all do you want to control? Assuming solar bypass valve and Heater? Do you have or plan to add swg?
Chris
great, at the moment no fancy automation needed but only ramping pump speeds for solar, SWG and later on a heater. V-green sounds like a winner then, any 22 AWG copper will wire will work? like this one ?That's great, and I ended up with the V-green due to budget woes as well after a big lightning strike took $5000+ by surprise. So here's how I would set it up if I were you:
You can set these up to run anything with that has a 12-24 v ac or dc when it runs. Not sure what kind of automation you plan to use for your system but any of them generate the signals you need to trigger speed changes without needing to use the RS 485, Of course you can do this if you want to using a protocol adapter.
- I would set the pump to run at low speed 24 hrs per day. This doesn't mean you have to run it 24 hrs per day, just that when you have it running (for example from a timer) it will run at low speed unless you have something running that requires a higher speed.
- If you have a bypass valve that closes to control the solar you can just split the 24 vac signal off the actuator that closes the valve and run that to "Step 1" and then set Step 1 to the desired speed (I run 3000 rpm).
- For the gas heater you can run a wire from the gas valve relay to "Step 2" and set that speed to whatever you want.
- You can do the same for the swg or just make sure the minimum speed is adequate for the swg.
I hope this is helpful.
Chris
Jim - I didnt see it working but looked very good and supposedly working before removal (guy showed me picture of his pool being filled. ) Do these 2-VST have high failure rate? What’s the best way to test those pumps before install? I bought these unions and plan to just do hand tight them in case pump doesnt work.Cay,
Did you see the IntelliFlo VST working before you bought it???
The SolarTouch should be able to control it using the RS-485 port.
Good luck with your upgrade,
Jim R.
Thanks Jim! RS-485 is on order $24 from ebay.Cay,
They don't have a high failure rate, but there is much more that can go wrong with a VS pump than a single speed pump.
The pump could be perfect...
It could have a bad controller
It could have a bad RS-485 port
It could have a bad motor..
If I had a pump with an unknown status, I would test it out by temporarily putting it next to the pool and run a threaded PCV pipe in the input and output connections to suck water from the pool and then back to the pool.. You could then check all the functions except for the RS-485.. If you have the RS-485 cable you could also connect it to your SolarTouch.
Jim R.
