How To Raise CSI?
revitup
884
Pawleys Island, SC
Fiberglass
Hayward Aqua Rite (T-15)
So I’m always a bit confused about how, or if I even need to, correct CSI. FG. Today’s test results (logs are viewable):
FC 10.0
CC 0.0
TA 60
CH 275
PH 7.4
CYA 80
Temp 89
Salt 3200
CSI -.62
Could bring CH up a little, or TA, but that doesn’t do much. Could raise PH a little but hate to mess with that, it’s always pretty solid between 7.5 and 7.8. I never have to add MA.
I see conflicting info which says CSI should be either higher than -.6 or higher than -.3.
How should I adjust for CSI or should I even bother?
Then low CSI is of no consequence to you. Keep pH in the 7's. Your SWCG is best if the CSI is kept below 0.
Reactions: revitup
I ran your numbers on my spin wheel and got a CSI of -.20. Could be I made a mistake, but I don’t think so.
Idk this is what I see:
Carribean Bay “Calypso” IG
Build Type: Fiberglass
Volume: 8500 gallons
Latest Test Result Summary:
FC: 10.0 (11 hours ago)
CC: 0.0 (11 hours ago)
pH: 7.4 (11 hours ago)
TA: 60 (11 hours ago)
CH: 275 (11 hours ago)
CYA: 80 (11 hours ago)
SALT: 3200 (11 hours ago)
TEMPERATURE: 89° (11 hours ago)
CSI: -0.62 (11 hours ago)
If you use the old web version of PoolMath on your computer you can tweak the numbers and see the results easily.
