How to improve sundeck jets
soleen
Active member
May 17, 2023
30
New Hampshire, USA
Pentair Intellichlor IC-40
We have two jets on the sundeck that are not very aesthetically pleasing. The plaster around them has been damaged because the pipes were not properly sealed before plastering during the buildingprocess. Is there anything I can do to improve these fittings? Are there large 5" faceplates available (the largest I was able to find is 3.5")?
When the fittings are removed, there are 2" pipes with female pipe threads (FPT).
Hi everyone,
I'm looking for some advice on how to temporarily remove water from my sundeck area. I need to do some repair work on the bubblers, which involves polishing the plaster with a grinder. I'd rather not drain the pool if possible.
My sundeck is about 12" deep.
Sundeck photos.
Can't. If you start using any kind of abrasive on that plaster you are going to end up with a mottled mess as the color will change to more like what you see around those fittings.
How about carefully smoothing just the part that was chipped, without touching the rest of the surface? Are there other suggestions on what can I do to improve these bubblers? I would use 5.5" faceplates, but I can't find anything larger than 3.5".
We had an issue similar to yours. Our pool builder drained below deck, cut out the plaster around the bubblers and replaced with tile.
This is an amazing idea! Would you mind sharing a photo, so I could show it to my builder? I think, this is exactly, what we are going to be doing, add some decorative tiles around the damaged area.
