Hi!
This is my first season with a pool, although I've kept a hot tub for 20 years. I have an in-ground 20x40 pool, vinyl liner, glass media filter, but I mostly use a manual PoolBlaster Max Li for vacuuming. I have both the regular bag (I think they call it a "fine filtration bag") and a silt & sediment (picture thin support hose material) bag. I've found that even running these two bags together, I'll still get blow-out from the exhaust while vacuuming, so I end up vacuuming the same stuff over and over, which is frustrating. As best as I can tell this is a super-fine algae debris. I was wondering if I can use flocculant with this vacuum, leaving my whole filter system out of it, aside from doing the recirculation (no filtering) prior to vacuuming. I wouldn't want to ruin the vacuum. I would prefer to not ruin the main bag, but am ok with having to discard one of the silt & sediment bags. I'm on a well, and it wouldn't be able to keep up with me using a hose vacuum through the pump going to waste. Thanks for any insight/advice that you can provide!
