It's take a bit of troubleshooting, but I finally figured out why I'm getting air in my pump and lines. Turns out I have a leak in the valve on the suction side of the pump. This has resulted in LOTs of air in my system. At low running speeds it has sucked in so much air that the pump is void of water in about 45 seconds or so, and it kicks into high to suck water back in.
I found the leak by using the soapy water test. After about 15 seconds of spraying the soapy water in between the automated controller box sitting on top of the valve and the valve unit itself (see photo), it stocks sucking in air and quickly results in no more air pockets.
Before I take it apart, my question is: what should I look for when taking it apart, and how might I fix it. I know if it's cracked, I'll have to replace the valve entirely, correct? But could it just be a o-ring problem? I'm not sure it looks like, and I hate taking things apart with no leads on how to fix, so any advice here in advance is greatly appreciated. Regardless, I'll try my hand it later and report back on what I find.
