I looked up pool putty but a lot of the reviews mentioned that it was only a temp fix as the chemicals in the spa would wash it away over the years. Maybe Plastaid?
Are you sure the water weld won't erode away with all the harsh chemicals?Since that is on the back of the tub go buy the Water Weld at HD. I used it to fix a cracked pipe in my hot tub and it worked great, The only thing is since it is a straight piece of fiberglass it may not stick very well but for $7 its worth a try.
In your opinion which do you think works better? Loctite or JBWeld? Also is there any prep I need to preform on the outside surface before applying it? Sanding, cleaning, etc.?I'd repair obviously from the back and also would use a smidge on the finger and press some into it from the top side after the underside is cured, also scraping it by with a straight edge like credit card so it'll be completely level.
Gotcha. Thank you. Gonna try the loctite one and see if that helps.I'd be very careful applying hammering /pushing as you see there's also a crack going towards the jet. If its very so slightly raised I may forgo messing with it and creating a bigger problem. I'd prep it from the back with a very light sanding just to remove the shine for best adherence. I've never used JB weld but the marine epoxy i have many many times with great success. You can also use short pieces of solid bare copper wire inbeded in the epoxy for extra rigidity across the crack and apply it really thick. It doesn't need to be pretty but rather strong.
