Hello All,
I am sure I saw this discussed on the forum, but I can't find the thread.
I am transitioning my pool from 'old way" to FTPC and must manually control the Intellichlor IC60 and no longer rely on the Intellichem and ORP to maintain the desired FC level. I set the ORP hardware setting in the Intellichem to 'NONE' (tried all the others also), but that does not seem to have released the IC60, I am unable to control it with the device buttons not ScreenLogic. The device buttons do nothing, the unit is stuck on 80% and ScreenLogic still says "Intellichem In Control".
I suppose if I disconnect the COM wiring from the IC60 it would operate manually, but I would loose control via ScreenLodgic, is there a better way?
Thank you!
Thank you!
