My pool was build in 2005. I’m in the process of replaster with StoneScapes midnight blue mini pebble. They on chip below tile all around the pool. Is this normal process? I told my pool guy that most replaster did chip all the old plaster out.
Beaumont, tx an hour away from Houston. Glass tile install today. Plaster will done Monday. After plaster is finish. How long do I wait to fill up the water? Do I need to add any chemical after water full to the tile. Is this reason price for $8000?
It’s expected to rain the next day after plaster finished. is this rain going to cost any trouble? Should I wait until weather is clear to do plaster?Our local expert says 6 hours before you start to fill your newly plastered pool. Read the following for a great new plaster discussion. Pool Plaster Tips for the Average Homeowner. But don't stop the fill once started until it's up onto the tile area.
And on the chemical question: Start up new plaster
I read this couple of time. The pool guy want to do acid wash after plaster finish to get the pebble out.If you are not given a Start-Up Guide by your builder then follow this one - https://www.nptpool.com/pdf/npc_swimmingpoolstart-upprocedures.pdf
Thanks, I will do thatYou can put a sock on the end as well. It does two things-filters the water and keeps the metal end of the hose from touching your pretty, new plaster.
Yes stonescape mini pebble midnight blue without SWG.
Day 1 #6 skip or do it?
6. Although optional, it is highly recommended to pre-dilute and add a quality sequestering agent using the recommended initial start-up dosage and then the recommended maintenance dosage per the sequestering agent’s manufacturer.
