How much CYA to add to go from 30 to 40?
azpooldude
Active member
May 14, 2019
30
Scottsdale, AZ
Hi, I feel like my CYA is getting a bit low at 30 (it's been gradually going down over the last few months; I use liquid chlorine only and muriatic acid to control ph.)
So I bought some stabilizer. I'm just wondering how much to add to go from 30 to 40 in a 20,000 gallon pebbletec pool? I don't want to over do it. Thanks!
Jimrahbe
15,340
Bedford, TX
Dude,
28 oz of dry stabilizer (CYA) will add 10 ppm of CYA to a 20K pool..
That is what Pool Math does for you, you should try it..
frogabog
2,833
Portland, Oregon
If you plug the numbers into the browser/web page version of Pool Math, you'll get a dry volume results so you don't have to weigh it. But, it's usually very close so balparking can work.
