- Jul 21, 2013
- 65,154
- Plaster
- Pentair Intellichlor IC-60
A heat pump bypass valve can be installed so the maximum flow rate is not exceeded when you have a powerful pump. Here is one from Aquacal…According to the graph posted earlier, the pump has a water flow of 55 to 140 GPM. The specs on the HeatPro list a min/max flow of 30 to 75 GPM, with a reccomended flow of 43 GPM. Is that going to be an issue?
