- How long to heat the pool if. . . . . . .
- The size of your pool IS 13,000 GALLONS with a depth range from 3.5 to 5'
- Your pool water temperature in January averages 52 degrees
- Your pool is an IG
- Your pool is Plaster
- Your filter is a 500 sf Cartridge
- Your pump is a Pentair 3HP Intelliflow VSF
- Your pool has a Pentair 400 Master Temp Heater Dual Thermostat
- Your pool is less then a year old.
- Your Water Test kit is a PoolMaster 5-way test kit
- Your pool has no spa, just a pool sweep and the depth is 3.5 to 5'
