BACKGROUND
I installed a new solar temperature sensor on my roof and I wanted to check if it is working properly on my Aqualink RS 2 system. There is no direct method to display Solar Temp but there is an indirected method using a DIP Switch that can be used as I describe below. It took me quite a while to figure this out, so I hope this procure will be helpful to other fellow pool maintainers.
PROCEDURE
I recommend that the Aqualink manufacturer modify the Firmware and Phone App software to always display Solar Temp along with Air and Water Temperature.
If this is too big of an interface and/or display change, then I recommend that they make the modification to display Solar Temp in the place of Water Temp whenever the Pump is off.
PROCEDURE
- Start the Aqualink Phone App and record the Air Temp setting.
- Turn off power to the Aqualink controller. This is required because DIP switches are only sampled during initialization.
- Turn on S1 Dip Switch #5 which turns on the Factory Adjustment mode as described on Page 45 of the Aqualink RS Installation Manual. This disables any Temperature Delays and Displays Solar Temperature.
- Turn on power to the controller and wait a few minutes while the system initializes.
- From the Aqualink Phone App select the WEB page and then select the Status icon on the bottom of the Home Page.
- The last line on the Status Page should read “Status: 0B”. This indicates the system is in the Factory Adjustment Mode and Solar Temp is now displayed instead of Air Temp on both the App and Web Home Pages.
- Compare the Solar Temp reading with the Air Temp reading you previously recorded. They should be within a couple of degrees if they are both in direct sunlight. If one of them is in the shade then there will be a larger difference but the two values should be in the same ball park if the Solar Sensor is working properly.
- After you have checked the Solar Sensor you need to put the Aqualink system back into the normal configuration mode by reversing the previous steps: Turn off power, turn off the S1 Dip Switch #5, and turn power back on.
- You can check that you are back into normal mode by verifying that the “Status: 0B” is not present in the WEB page Status display.
