Good morning. I ran my hot tub for the first time last night and I noticed something that was unclear to me. I don’t have automation so I manually turn valves myself. I changed the position of the suction side valve to pull water from the hot tub and set the valve on the return side to flow only into the hot tub. My concern is as water is being circulated to and from the hot tub, how is the water that is being splashed over the hot tub into the pool from the air blower being replaced? I ended up opening the suction side valve slightly to pull mostly from the hot tub but also slightly from the pool to compensate for the water that is splashing over the hot tub to the pool. What is the correct way for this to work. I hope my explanation makes sense.
