Horse pool
Arowdy1
15
Sw louisiana
I bought a house that has a horse pool. No filter. Has a pump and skimmers .it's 21000 gallons . I doubt they ever cleaned it as I have never seen the bottom yet . Lol my question is what size filter system would work ? I don't know what my pump pushes. I attached photos of what I have to work with. Any help would be appreciated . Thank you 20250406_142953.jpg20250317_120157.jpg20250409_180451.jpg
Can you get a picture of the pump id plate? What you’ve posted is the motor plate…Looks like a pentair superflo or Whisperflo wet end.
I would get a very large sand filter. This is not a low bather load residential pool.
The horses are going to constantly drag a lot of dirt into the pool and the filter will need cleaning often.
A sand filter with a MPV that is plumbed for backwashing will allow the filter to be regularly cleaned.
+1 on the sand filter and MPV. I would also want to be able to vacuum to waste as I would assume there is stuff at the bottom of that pool that you would rather vacuum out and not go into your filter.
I agree with ajw & jj - get the largest sand filter with mpv you can find especially if there will be horses involved (they shed alotttt)
250#- 300# should do.
I assume there will be plenty of space to direct backwash/waste water to?
You’ll likely need to expand your pad a little.
I will grab more pictures tomorrow . It's super deep ! Where the rail ends it steps off . I'm still trying to clean it . I was going to drain it and clean it . But I'm told not to because the water table here is too high . So I'm shocking it . And brushing it . I put socks on the baskets and I clean them out every 20 min or so. I'm kind of at a loss on how to get it clean without a filter . I bought a robotic vaccum. I figured it would die fast . It's pretty green . Although right now it is cloudy blue . Until I brush it.
Reactions: HermanTX
You could vac to waste with a manual vac while simultaneously filling with the hose if you’re pole reaches the bottom. You’d need to go slowly in order to prevent stirring things up too much. Its more of a vacuuming blind situation in the beginning.
It will be very difficult to do the
SLAM Process without a filter.
If you don’t already have one of the recommended test kits (Taylor k2006c or Tf100/pro) get one ordered asap.
Test Kits Compared
Reactions: Arowdy1
Well this one is fun… I’m going to separate from the herd mentality here and suggest a two-stage filter design. With ten horses and a dedicated pool, I am going to assume that you are an expert in “how to turn a big fortune into a little fortune”, and will adjust my design suggestions appropriately. (For those outside the loop, this is a horse ownership joke. I’ll have one too when I get to be a big boy).
I am not a reigning expert around here on swimming pools. With that having been said, what you have here in my mind is really more of a hybrid between a swimming pool and an aquatic pond. You want it clean like a pool, but it’s got much more load in terms of dirt and biologic than the standard swimming pool that is usually talked about here. This is all about you, since the horses don’t give a d***.
When I was in college, I spent my summers working at a waterpark (Schlitterbahn, thank you for asking). There we ran commercial pool protocols, and while I was a diver and really did little with the pool side, my direct boss was radio codename “Pool Boy”, and I learned a great deal from him. We had this aquatic fish pond over a 400’ boardwalk deck leading to a restaurant that never seemed particularly well thought out to me.
I somehow got dragged into filter maintenance one summer. We had three 500 gallon filters on that system that kept getting plugged up quickly, and we had to drag them out and empty the sand and gravel so we could swap in some larger filter media. Putting larger media in effectively created a pre-filter that caught the big gunk and thus “saved” the finer filters for the smaller stuff. We got the job done. (Fun side note: when I got out of college [construction science] I couldn’t get a job so I came home and found one as a PM for that same company while they were building a new waterpark. Hit me up if you need to know how to build a wave pool or lazy river.)
All this is to say if I were you, I would be thinking about putting in two filters instead of one. Stage 2 is your standard sand filter mentioned by everyone else here. Stage 1 is the “pre-filter”, in which I would run something like pea gravel, or a mixture of pea gravel and something larger than sand but smaller than pea gravel to fill the gap. (If memory serves two media will fluidize and settle appropriately when you backwash the filter. I think we ran sand and gravel together as an example). I’m thinking of decomposed granite type consistency, but I don’t know if that would contribute to water chemistry and I’m sure there’s a defined product to use.
Those are my thoughts… worth what you paid from them.
One more opinion: until you have at least a temporary filtration system in place, I personally wouldn’t spend too much time on it. It’s really weird that there isn’t already a filter plumbed on it. Makes me think it broke and was abandoned for one reason or another. Anyhow, at this stage if it’s sat looking like that for some time then its already nasty and another week or two won’t kill it (you said you just bought it?). You can spend a bunch of money on chlorine in the meantime, but until you’re reliably removing waste, old and new, from the pool, you’ll keep having problems. I think step one for you is to plumb a filter, any sand filter, even if its just temporary to buy you (and us) enough time to study how this pool works. As others have mentioned, plumbing in a MPV valve or a diverter so you can vacuum directly to waste is a great idea. You can go with the size previously recommended above or just buy the biggest one you can get.
You don’t have a filter right now, so I don’t think that putting a sock in the filter basket really makes any sense. It’s getting clogged quickly because the sock is probably the tightest filtration in the whole filtration system (sock, basket, pump strainer). Pool filtration is talked about in microns and you’re still stuck at the inch and millimeter scale. Once you have a filter, you’ll first vacuum the big crud out to waste, and then start running the filter system while you shock.
Regarding emptying the pool, you don’t have to do that right now if you’re worried about the water table. What kind of access to fresh water do you have? The TFP pool school and wiki have good notes and protocols about doing gradual water changes which should accomplish what you’ll need to do to bring the chemistry into line.
Everyone here can give you advice, but if you’re running horses through it then accept up-front that there may be a little trial and error. That being said, there’s a lot of good applicable wisdom here.
Reactions: Mdragger88
This is in the grass next to pool. I have no clue why .
Those are the only valves. So far I have figured out the 2 black ones run the 2 skimmers . No clue on ball valve yet . I'm afraid to turn it. Lol
There are 4 black mats . I never saw before . Lol I can now see 2. Lol
One skimmer in deep end . On midway in skinny part .
I see moving water in skinny part when pump is on. No clue how many . There are lights in the pool .
Right now yes I'm spending a fortune. Only because it's what I call a "polio pit " swamp . I don't like more mosquitos etc . I want to know if a gator is in it ! Lol
Yes I'm an expert at reducing fortunes ! Lol if you ever need advice on how blow they money with horses . I'm willing to give you expert advice ! Lol
2 stage filter sounds like too much for this old ladies brain lol .
Horses get washed before they enter . But yeah I get it !
Based on that I’m going to tailor my attitude and recalibrate.
You have a pump and you have your 2 skimmers. The third incoming line is probably the main drain (which can be pretty much closed. Not 100%, but 90%). Water goes in and out, round and round the pool and this is good. You need a filter first, and you need a regular dependable source of chlorine second. That floating chlorine basket works fine in the interim, but its really not ideal for 20 thousand gallons in the long run.
Question 1: Are you going to try and maintain this 4 legged car wash by yourself, are you going to have staff on hand do it (presuming…), or will you hire it out (pool boy)? Given that you are dealing with horses, they are not likely to follow your rules and they will most likely step on any robot, so manual maintenance is going to be part of your deal. Somebody is going to have to vacuum this pool every now and then and add chemicals. If you’re going to be paying a pool boy to show up anyways, then we can relax all this talk of 2 stage filter nonsense.
Question 2: How price- and labor-sensitive of an issue is this for you? In my mind we can get this solution started:
  • Option A - “DIY” for ~$1.25k - $1.75k worth of parts if you or an employee are handy with simple PVC plumbing (it’s really fairly simple). I wouldn’t ask my mother to do it, but you’ve made your way over to this website so I won’t presume you to be frail or helpless. I know horse ladies who chew tobacco and spit tacks…
  • OR we can quickly hire it out to a local pool boy (option B). I’m guessing around 2x the cost of the DIY route. I haven’t had to price one. Never hurts to have a relation with a local pool boy…
  • Option C, let the pool boy install both the filter and a “salt water generator” for chlorine production. This is likely to get you to the end result you want with the least headache. I’m not going to try and guesstimate that price on principal because you and your pool boy need to be happy with your business relationship. Cap the expense south of $8k and recognize it can be done far cheaper but you’re paying a luxury tax.
  • Option D - we find you a backhoe operator and stop the bleeding now before it starts. This makes us all of us on-line people sad, and I heard the polo ponies all got together to vote “Neigh”.
Let me know where you fall and we’ll get you moving in the right direction.
